Coating for Aluminum vacuum chamber
I'm searching a surface treatment that would improve the corrosion resistance of aluminum alloys while be completely free of any porosity and resistant to abrasion.
Anodization is not the appropriate surface treatment because its pores absorbs water which cause process variation.
RE: Coating for Aluminum vacuum chamber
What is going to cause corrosion in a vacuum chamber?
A corrosive gas inserted in the vacuum chamber.
Electroless nickel, chromium plating, a thermal spray coating...
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
This is why 316L SS is commonly used for vacuum chambers.
