How to make a pyramid?
Im trying to model a pyramid like the egiptian pyramids, Im probably missing something, but I tried angled planes 3dsketches and other aproaches and I can't get what I want.
Any help would be greatly appreciated. Thanks
RE: How to make a pyramid?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
2) Create a 3D sketch and place a point at the required apex position and close the sketch.
3) Use the Loft tool and select the two sketches.
Jeff Mirisola, CSWP
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Cheers!
The Great Pyramid is 755.5ft at the base and 485ft tall. Does SW08 still have that 1024m limitation?
I wasn't thinking about the '08 thing, it was simply open at the time, so I used it.
PEU - I still created a loft, but didn't use a 3D sketch. I simply offset a plane the distance needed (
Jeff Mirisola, CSWP
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Here's a screen capture of the pyramid, showing dimensions.
PEU - I still created a loft, but didn't use a 3D sketch. I simply offset a plane (from the top plane) the distance needed (5820 inches) and put a sketch point on the origin, while using a centered square on the top plane.
Jeff Mirisola, CSWP
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
mncad
