Main Centrifugal pump manufacturers????
Hi everybody!!!
I´m project engineer and I´m working in a  Rankine cycle project. We are in the state of the project related to the pump definition. My question is, could anybody tell me  a list of the best centrifugal pumps manufacturers?
Thank you very much
RE: Main Centrifugal pump manufacturers????
My I suggest you type "pump manufacturers" into your internet search engine, and press "enter"?
Each pump OEM has their own niche. What is the application?
Flowserve and Sulzer are the two I go to most, but they fit my applications...
"Why don't you knock it off with them negative waves? Why don't you dig how beautiful it is out here? Why don't you say something righteous and hopeful for a change?" Oddball, "Kelly's Heros" 1970
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Off the top of my head I know of at least 4-5 different kinds of centrifugal pumps...but a lot of the manufacturers make a wide variety of pumps.
I'd go with Goulds or Flowserve, they make a variety centrifugal pumps and we rarely have major issues with.
KSB-Ajax
Toroshima
Nijhuis
Flowserve
Goulds
Warman
Weir
Sihi
Sundyne
ITT Flygt
Grundfos
GIW
Sala
Orion
Alfa Laval
It depends what industry you are in. Building services, petrochem, oil & gas, mining and minerals, power, nuclear, water and wastewater, food, pharmaceuticals, cement etc etc.
What type do you want submersible, horizontal, vertical, turbine, centrifugal, dosing, boiler feed etc etc.
What standards do you want API, ISO, EN, BS, JIS ....
Suggest you go to www.mcnallyinstitute.com and start reading then do an intelligent Google search for the correct manufacturers for your need.
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
www.waterhammer.bigblog.com.au
dont forget of course CDR Pumps !!!!!
For any of you who know the commercial for Carlsberg Lager, they would say "If Carlsberg made pumps, they would call them CDR Pumps"
Ash Fenn
www.cdrpumps.co.uk
Mecheng60
KSB ( GIW, ITUR, DP PUMPS,..)
ITT ( GOULDS, A-C, Vogel,...)
FLOWSERVE ( WORTHINGTON, BYRON JACKSON, PACIFIC, PLEUGER, DURCO, UNITED CENTRIFUGAL PUMPS,...)
EBARA
SULZER
THEY MANUFACTURE ALL KIND OF CENTRIFUGAL PUMPS (VERY NEARLY)
agiraias, what type of project are you working on?
Plymouth Tube
Have you heard of Pumping and Technical Services Ltd?
Based in the UK try their web site: sales@pumptech.co.uk
Flowserve, Sulzer, Goulds
ITT
Flowserve
Crane
Do a web search for local distributors, then contact the distributors for application assistance.  Distributors' application engineers can usually be counted on to point you in the right direction.
