Identification of quench cracks at tooth root
I have a small gear, 26 DP / 46 teeth, fabricated from 8620. A recent gear tooth failure problem was potentially linked to the existance of quench cracks. I question the observation only on the basis that only a single tooth was found to be cracked. Seeing as the entire gear would be submitted to the same heat treatment wouldn't I expect other teeth to exhibit the quench cracks? Comments?
BCK
RE: Identification of quench cracks at tooth root
Where did the tooth fail and what is the orientation of the suspected quench crack relative to the tooth fracture?
"..... only a single tooth was found to be cracked."
Was it inspected with wet magnetic particle ?
Did the magnafluxer check it in several steps, with a new magnetization for each orientation?
After additional inquiry I am finding some hesistancy from the metallurgist regarding the initial failure diagnosis, e.g. not all teeth were checked just the ones near the failure point, not sure if it is a quech crack, etc... Is it possible to look for some heat treat residual material in the crack to determine if it appeared during quench?
You can examine the fracture with a scanning electron microscope (SEM)and determine if there is intergranular fracture at the crack initiation. Quench cracks are intergranular; fatigue cracks are not. Overload fracture, especially in a carburized case, may exhibit some intergranular fracture in the heavy portion of the case, but near the intiation point, the fracture should be a predominantly quasi-cleavage.
swall,
Thank you for the very helpful guidance. 2thumbsup
BCK
