Guidelines for galvanize bolts
If the nuts and bolts are galvanized, should the threads on the nut or the threads on the bolt be tapped?
I remember reading that the female threads on the nuts should be tapped after hot-dipping such that all the zinc coating is removed from the thread. If so, would it still be necessary to tap the coating on the male threads of the bolts?
By the way, a Simpsons rep told me zinc coating and galvanizing is two different things. Can somebody tell me the difference? Which would you use for bolts and nuts?
RE: Guidelines for galvanize bolts
Hot dip galvanizing is one type of zinc coating, and the best type for many applications. But one limitation is that the thickness of the zinc in the finished galvanized product is directly related to the thickness of the base material, so thin material doesn't get much coating, and other processes give better protection.
Coatings commonly used for priming steel are inorganic zinc silicate, which requires near white metal preparation and provides excellent protection; and zinc filled epoxy primers, which are somewhat more forgiving of preparation, thus applicable to recoating projects.
Knowledge of coatings among structural engineers is in most cases woefully lacking. Most of us had no education about coatings, and have had little training since. Such an important facet of the work we do deserves better.
Galvanizing involves immersing the parts in liquid zinc. This produces thick coatings (> 50 µm).
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
http://www.pfonline.com/articles/100103.html
Cory
How is zinc coating applied different from mechanical plating?
Thanks!
Don't know whether coating or mechanical plating is better.
As to coating, think paint.
Advantages: produces thin coatings (prevents problems associated with clearances between external and internal threads); many plating companies (low cost, high availability)
Disadvantages: produces hydrogen during processing, so high strength parts must go through deembrittlement process; toxic chemicals used in this process; only suitable for indoor/light duty applications
Hot dip galvanizing
Advantages: produces thick coatings needed for outdoor exposure
Disadvantages: requires more zinc (high cost); large thickness requires more care with thread dimensions before and after coating to insure no problems with mating parts; high temperature of molten zinc will temper (reduce strength) of high strength parts
Mechanical plating
Advantages: produces thin coatings similar to electroplating; does not produce hydrogen during plating, so it is preferred for higher strength parts (like hardened washers)
Disadvantages: fewer suppliers, which limits availability
There is a fourth type of coating: coatings containing zinc flakes/powder. These use either organic or inorganic binders, have thicknesses of approximately 5 to 30 micrometers, may contain friction modifiers to control the torque/tension performance, and have corrosion resistance greater than plating. These coatings are applied by immersion in liquid suspensions of the binder+zinc followed by spinning (to spread the coating evenly over the part surface) and then curing in a furnace. These generally do not produce hydrogen embrittlement.
Cory
Hot-dip zinc-coated nuts shall be tapped after zinc coating.
Mechanically deposited zinc-coated nuts for assembly with mechanically deposited zinc-coated bolts shall be tapped oversize prior to zinc coating and need not be retapped afterwards.
Threaded components (bolts and nuts) shall be coated by the same zinc-coating process.
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
Cory
Cory
The first time I ever saw freshly blasted steel, I thought it had been painted silver.
Hg
Table 24
