Pinion Mass Dampener
So I was wondering if pinion mass dampeners that are found on some vehicles are to compensate for the harmonics generated due to pinion angles within a certain range. Am I wrong in thinking if the drivetrain were in perfect alignment for an independent rear suspension vehicle (ie zero angle between transmission tailshaft/driveshaft, and zero pinion angle) one would not need a mass dampener on the pinion?
RE: Pinion Mass Dampener
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
And that's just the "source" end of things...
Mike Halloran
Pembroke Pines, FL, USA
I imagine some vibrations are induced by CV joints in the axles if the diff centre is mounted rigidly to the chassis.
Also tyres might set up some reaction as they are never perfectly round with perfect side wall stiffness in all directions.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
If the engine, transmission, and differential were not connected rigidly, I would assume that the deflection in engine, transmission, and differential mounts would cause the angle to change slighlty (< 0.5 degrees for arguments sake). This is why I would use universal joints.
The angle does change.
You can't use a solid bar like most of the rest of the world?
It is about 4' long. The boat flexes a bit (never measured) and the shaft never fails.
Nor did they fail in the front engine/rear transmission Pontiac Tempests, a few Ferrari models, and the latest few years of powerful Corvettes.
