Welder Qualification
Does any ASME piping code specify that the first two welds by any welder
need to be radiographed as qualifying shots?
If so, would that be per welder, per procedure?
Thanks QCMIKE
Thanks QCMIKE
RE: Welder Qualification
QCMIKE
Steve Jones
http://www.pdo.co.om/pdoweb/
A natural gas line was butt welded when the customer spec called for socket welds.
At a meeting it was mentioned that a butt weld was stronger than a socket weld and this was immediately contradicted by one of the attendees.
Which would it be?
QCMIKE
Steve Jones
Are these materials impact tested any differently than normal test for these materials?
QCMIKE
Gerald Austin
Iuka, Mississippi
http://www.weldinginspectionsvcs.com
