Defining a Sphere to Intersect Solid at Desired Points
Im currently designing a screw, and for its hexagonal head, I need a large sphere to intersect it in a way that leaves (from top view of the screw) a circle inside of the hexagon at a certain distance from the corners. Can I have a sphere intersect the extruded hexagonal head at certain distances from the top and do a boolean intersect?
RE: Defining a Sphere to Intersect Solid at Desired Points
But...
Why bother with the separate body creation if you are able to create the revolve in the right place? Just make a revolved cut.
