threaded hole question
I need to make a threaded hole through the length of a cylinder
Cylinder diameter 50mm
Cylinder length 40mm
Threaded hole 1.250-18 (through all)
Am I correct that 1.250 is the diameter , and that  18 is the pitch ?
I have never worked with inch before, so how do I select this  1.250-18 thread ?
The hole wizard?
Toolmaker
RE: threaded hole question
Tanks ctopher,
But how can i obtain  1.250-18 UNEF thread specification, needed for setting the hole wizard settings?
Toolmaker
found on the internet
    major dia:              1.250
    tpi:                        18
    pitch dia:                1.2139
    minor dia external(a):   1.1839
    minor dia internal(b):   1.1899
Toolmaker
