REPEAT COMMAND
REPEAT COMMAND
Is there a way to get a command to automatically repeat when using keyins?
ie. The same as double clicking the icon
RE: REPEAT COMMAND
Ok, I'm now guessing what you are after...
You can copy paste features or even drag them in space and like windows if you hit CTRL button before you drop it, you will get an independent copy of the feature with same values.
I frequently use drag and CTRL drops with fillets/chamfers:)
RE: REPEAT COMMAND
RE: REPEAT COMMAND
RE: REPEAT COMMAND
EXAMPLE:
Double click on the "point" icon and create a point of some escription.
Hit OK
The point icon returns automatically and continues to do so every time you click OK.
I want to do this from the command line
RE: REPEAT COMMAND
RE: REPEAT COMMAND
Anyone know how to create a cutaway view in a Catia product.
Like a section however not defined by a plane rather an extruded polyline passing through the product.
