Roller Bearing Design
Does anyone know how bearing manufacturers go about making the rollers for roller bearings? My company is currently producing a roller vane pump and is looking for ways to take cost out of the rollers. I figured that bearing manufacturers must have figured out the cheapest way to make this type of part. Thanks!
RE: Roller Bearing Design
Straight rollers can start with coil drawn to diameter, cut to length, ends pointed, heat-treated, diameter ground.
Each plant or product can have various machines, materials and processes depending on the details, so there are many variations on an answer, I gave the basics.
If I was looking to reduce costs, I would get a few detailed quotes from manufactures who do this type of work. There are various types of info on the net, a search should pull up a few. Good luck.
Business Page http://mech.e.tripod.com
Motorradtraum....www.tailofthedragon.com
http://med
Russell Giuliano
