ground fault and shunt trip devices in commercial kitchens
If you are suppose to shunt trip any 125v devices underneath an exhaust hood, and all 125v, 15-20amp devices in the same kitchen shall be protected by ground fault devices (breakers or receptacles), Then what do you do when you have a device that falls under both of thos rules and requires shunt tripping because of being underneath the hood, but in the other hand, also requires ground fault protection. I really didn't want to use a GFCI receptacle on a shunt trip breaker because that would locate the GFCI receptacle behind a rather large gas stove (where it would be very hard to reset should it trip)
RE: ground fault and shunt trip devices in commercial kitchens
If you need to shunt trip more than just a handful of circuits it may be less expensive, and far simpler, to have a panel dedicated to shunt trip load and just shunt trip the panel main.
