CREATING A FORMULA
CREATING A FORMULA
CREATING A FORMULA
I have a plate that has a constant thickness of .500".
However I have a maximum and minimum length and width I can use in my application.
I created the plate with two length parameters with multiple values one for length and one for width.
I can select the parameter and choose in a drop down list one of the two.
My question is under the parameter for stock size is there a way to have this value change based on the other two parameters?
For example under parameters I have `Stock Size`=
and `Maximum and Minimum Length`=34.000in or 27.500in depending on what is chosen.
and `Maximum and Minimum Length`=22.500in or 20.750in depending on what is chosen.
RE: CREATING A FORMULA
yes but you need a KWA license to use rules
