I need an estimate for the polar moment of inertia
Folks,
I need to estimate the pitch moment of inertia of a vehicle for Vehicle Sim.
I have the corner weights as well as track and wheelbase.  My first thought was to treat the vehicle as a dumbell with two different size masses.
The pitch moment would be the sum of the mr2 with r being the distance between the cg and the front and rear axles respectively.
Any ideas.
Jim
RE: I need an estimate for the polar moment of inertia
That's not a bad approach, rule of thumb is that it is the same as the yaw inertia, or a bit less, and the NHTSA publishes a list. Sorry haven't got the link.
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
What's the vehicle? Maybe its laying aroung here.  Other option is to easure it yourself...
The corner weights and track wheelbase are not enough to determine pitch moment. E.g. a mid engined car might have a far lower pitch moment for the same corner weights than a front or rear engined car.
Pete.
Thanks everyone.  I fully understand that I don't have enough to determine the polar moment.  I was hoping someone had a good rule of thumb.
I do have the NHTSA paper with their data and some of it seems a little off with respect to weights.
Thanks anyway.
Jim
