Installing grouted stone gravity wall
I have to bid on a project that has grouted stone gravity walls up to 11 ft high and 15 ft wide at the base. What kind of production rate should I expect? How many people in the crew should I need? Any tips???
RE: Installing grouted stone gravity wall
Dick
Production should be about 2- 3 pallets per day I think about 56 bags per pallet of cement and 70 bags /pallet if you are using bentonite.
This rate can be increased by using more automated or larger mixer equipment but for your purpose this should be sufficient.
Intrusion Prepakt /marineconcrete.com
