Coil Power Control Design
I would like to control the 60Hz AC power to a coil that will be used as a demagnetizer. I do not want to use a rheostat, but rather a state-of-the-art digital circuit that can be adjusted by an operator.
RE: Coil Power Control Design
Not high tech but a variac will work.  Electronic-single phase PWM servo amplifier driven by a variable amplitude sine wave.
Do you want to vary the voltage, current or both??
I would like to control the voltage.
