Meshing problem
Meshing problem
Meshing problem
I am trying to mesh an assembly. It has 11 parts, however one part is not showing after meshing though no error was displayed during meshing. The same part, if meshed as a single part meshes without any issue. Also, during meshing, total number of parts is showing as, for example, 2 of 11 but immediately changes as 2 of 10 and finally ends with 10 of 10.  Obviously, the analysis fails to run and showing an  error "may not be insufficient restraints". Why is that one part not showing after meshing ? I think that is the main driver for the problem in the analysis not running. Please let me know. Thanks.
RE: Meshing problem
Hi
I think you have not updated the analysis in cosmos.
go to cosmos, right click on the analysis, click update components.
you should see 11 components after that.
jus try this.
