Produce an excel report from a BOM
Ladies and Gentlemen
Is there away to produce an excel file from an assembly BOM information?
I know you can produce a txt file then copy paste. I want to skip that step.
I am running WF3.
I am running WF3.
RE: Produce an excel report from a BOM
ht
-Hora
Cadcamguy.........not as well as I wanted to. I imported a neu file and got rid of the few paramters not needed in each part.
I have figured out how my sawdust furnace should work and am creating some amazing heat using wet sawdust. Actually you can burn any bio fuel in it as long as its has some moisture. and its naturally aspirated! I have an order for 10 of them.
Next project is to finish the design of and build a small cnc mill. Motors were bought today.
