Large Welded Pipe Yield Strength
I am trying to find out the yield strength of a 36" diameter pipe which will be welded together. Any input or direction to a properties page would be helpful
RE: Large Welded Pipe Yield Strength
We normally specify wall thickness of 3/8,1/2,5/8,3/4, or 1"
If this is existing, check it using 35 ksi. If this works, great. If not, you would probably be better off getting it tested, or providing reinforcement based on the assumption that it is 42 ksi than you would be to assume a higher strength.
