command similar to shrinkwrap
Hi
We know that the file in proe can also be saved as 'shrinkwrap' with levels as we require.So i just want to know is there any similar command or command which does similar function in catiav5
thanks in advance
thanks in advance
RE: command similar to shrinkwrap
My first impression is that it sounds like something we have in DMU optimizer workbench called "Wrapping" but I can't be sure that is what you are looking for if you don't elaborate some more.
