Saving PDF of drawing creates display problem
I am having a problem with a drawing.  I am trying to draw a reference circle on top of one of my drawing views.  After I draw this circle, its line color changes to a faded line.
If i do a print preview,the circle is visible
If I save the file as a pdf, the circle is invisible
Any suggestions on how to prevent the circle from becoming invisible when i go to create a pdf?
RE: Saving PDF of drawing creates display problem
I could not repeat what you are seeing but you may want to try to change the setting in Page Setup to Black and White.
