Why have redundant pressure relief on piston/diaphragm pumps?
I have simplex diaphragm pumps from Milton Roy that are equipped with internal relief valves. I see piping diagrams that specify external relief, from them and other vendors. In my case I would relieve back to the suction line with a pulsation dampener to absorb the minimal thermal expansion, at my 450 lb/hr pump rate.
Why the dual relief? Is there a code to comply with in chemical service?
Is this a case where the vendors do not want the internal relief device to be a safety device for the piping system, but rather only equipment protection?
RE: Why have redundant pressure relief on piston/diaphragm pumps?
Johnny Pellin
