Copper Tailings Erosion of Centrifugal Pump
I'm trying to reduce erosion in a copper tailings pump.  I'm looking into the following:
1. Replace the liner material
2. Replace the wear ring material
3. Use a spray coating
Can anyone tell me what materials I should be looking into and which are most resistant to erosion in copper tailings service?
RE: Copper Tailings Erosion of Centrifugal Pump
How acidic is your solution?
What are your present materials of construction?
Still trying to help you stop corrosion.
formerly Trent Tube, now Plymouth Tube
eblessman@plymouth.com
or edstainless@earthlink.net
