Photoworks Toolbar Disappeared?
My computer was running slow, using SW '07, even after cleanup and defrag, so I downloaded a registry cleaner and after using it my photoworks add-in was screwy, so I restored the registry to its initial state but the problem remains: the photoworks toolbar is gone. I can still access material editor, lights, scenes, etc, either through the render manager tab on the right side of the screen (behind feature manager) or through the task pane tab on the left side of the screen... but I can't get to photoworks 'options' or 'render to file' if I can't access the toolbar.
So, does anybody know if anywhere there is an option to show or hide the photoworks toolbar? I think it should automatically be there if photoworks is an active add-in, but may be, and hope I am, wrong.
Otherwise, any ideas on how to fix the problem? I've already tried renaming the SW registry entry, and thus resetting SW settings, to no avail. Help appreciated!
RE: Photoworks Toolbar Disappeared?
Which one did you use?
Probably the simplest fix would be to insert the install CD/DVD and do a repair. If that doesn't work a complete, clean re-install may be necessary.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
Dan
www.eltronresearch.com
Jeff Mowry
Jeff Mowry
