4140 processing
4140 processing
4140 processing
What's the difference between "4140 quench & temper" and "4140 heat treat & stress relieved"?  I thought the terms were interchangable but my suppliers seem confused.
RE: 4140 processing
4140 heat treat and temper though not a scientific term might mean normalize and temper. The other term refers to a faster rate of cooling in oil or water or polymerfollowed by a tempering cycle.
Save water Drink Beer
RE: 4140 processing
so the term "heat treat and stress relieve" is too loose a term?
RE: 4140 processing
Yes. Heat treat is a common term used for annealing.normalising,tempering solutionizing,etc. What process is exactly followed has to be specified.
RE: 4140 processing
Go to http://www.matweb.com and search for 4140 steel. 32 results. Note the wide range of tempering temperatures.  A lower tempering T will give greater strength but less ductility (elongation at break). Click on any listing to see the properties and specifications (ASTM, BS (UK), DIN, JIS, SAE AMS, etc.).
RE: 4140 processing
Great, thanks for the help.
