Pressure Tap and sensor location for orifice plate
Does anybody know the correct spacing for pressure taps before and after an orifice plate. I read in a book that D and D/2, Flange, and corner taps were recommended. However, the same book also had a figure for the pressure tap locations at 2D and 2D.
Also, where is the best location to mount a temperature sensor relative to the orifice plate.
RE: Pressure Tap and sensor location for orifice plate
You can use corner taps, flange taps (located 25.4mm up- and downstream) or D and D/2 taps. "D and D/2 taps" imply the upstream pressure sensor is D away, and downstream D/2. Any other spacing of taps is going to give you increased uncertainty relative to published data correlations. The above gives a correlation formula that depends on the tap location; I would bet that a published correlation in a book somewhere doesn't include those effects, since they are generally pretty small...but it's safest to use corner taps IMO.
From the above reference, the preferred method is a downstream tap. The temp sensor or densitometer well, of diameter < .03*D should be located at least 5D upstream, or at least 4D to 8D downstream depending on the diameter ratio d/D (β).
Pipe taps are no longer allowed.
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
The harder I work, the luckier I seem
Why are pipe taps no longer allowed?
"sending you a copy" is against the law.
The committee found that the quality control on field installed pipe taps was universally inconsistent and found that improper taps were creating excessive uncertainty. I just found that my copy of Part 2 is out of date by a few years so I just bought a new copy. I'll let you know if they've added them back in .
David
David Simpson, PE
David
