Control algorithm in Simulink
I need to expand my closed loop system model with an algorithm which needs to be activated at a certain point in time, not at t=0. Obtained results need to be forwarded back in closed loop. This system uses PID control and need to control output variable during complete simulation time. Problem is how to switch on such algorithm at a certain time-point and than send such results back in closed loop. Thanks.
RE: Control algorithm in Simulink
Put your algorithm  in a triggered subsystem and just trigger it on when you need your calculation.
Kind Regrads
Phaneas
