I/O for CSS PUMP
I/O for CSS PUMP
Just graduated as an electrical engineer.
Anyway, I am evaluating I/O's for a CIP System. On one of their CSS pumps, it said 2in/2out, with Analog 1in/1out. What would these I/O's be? The analog I/O might be for a VFD and the other 2in/2out I'm guessing is running/fault at the input side and reset/? at the output. I'm not sure...can anyone explaing why there are 2in/2out?
Thanks!
Thanks!
RE: I/O for CSS PUMP
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
Albert Einstein
