Apparent Intersection
In drawings I have a end view of a profile. It is a filleted equilateral triangle. I need to dimension the height of the triangle. This dimension is from the base to the apparent intersection of the 2 sides.
In autocad we have a snap option called "apparent intersection", this enables us to grab this point easily.
Is there a option in Solidworks?
BMR
RE: Apparent Intersection
In SW it's known as a Virtual Sharp.
In a drawing view (or sketch) select the two lines which intersect and then select the Point icon in the sketch toolbar.
cheers
That was useful. Thanks
I wish there was a way to bring in a dimension without this construction point
It can be if the geometry and features are created to suit, and if the Insert > Model Items dimensions are used.
cheers
bmrao123,
It doesn't have to be displayed as a construction point.
Go to: tools/options/document props/detailing/virtual sharps  and chose a different display style.
Timelord
Timelord,
That was a wonderful suggestion. This appears that this is exactly what I need. But, I cant view these points ( even when changed different pt style) on my drawings to use them for dimensioning.
Is there any switch any where?
Any comments?
BMR
In a drawing view select the two lines which intersect and then select the Point icon in the sketch toolbar. The VS will appear and will be selectable for dimensioning.
cheers
CBL,
Though you have answered to my requirement.
I am figuring out if there is a way I can get all the virtual points automatically.
Just like temperory axis for round parts and fillet features.
Rgds
BMR
If you have placed the VS in a models sketch, it becomes part of that sketch. If the sketch is left showing in the model, it will automatically show in the drawing view if you have the View > Sketches option selected.
cheers
