GPS software
GPS software
GPS software
I'm looking for GPS/GIS software that is good for:
importing gps points
calculating distances between points
regurgitating elevations from those points
has decent drawing capabilities
Anyone have any suggestions?
I'm not exactly 100% in-love with All-topo pro.
RE: GPS software
I'd say it really depends on what your application is.  I really like Terrain Navigator Pro (TNP), but I definitely wouldn't say is has anything other than very limited drawing capabilities, I would call it "annotation capabilities." It will calculate distances and areas though, although the accuracy is limited by the fixed map scales. I'd round it off at about 10 linear feet and maybe 100 sqaure feet.
TNP is a USGS mapping software that you typically purchase for an entire state.  Each state typically costs about $300, but what's nice is that you can import GPS points (or points from any coordinate system for that matter), or create points for any coordinate system and transfer to the gps device.  It provides ballpark digital elevation data for wherever you have the mouse located, and what I find to be the most useful feature is that you can export the USGS maps (or sections of the maps as defined by the user) as georeferenced tiff files that can be imported directly into your Cad program so that it "falls" right into place.
Again, it may not be the best for your particular application.  When I want to do what it sounds like you're wanting to do, I'll convert the GPS points to state plane coordinates (since I usually work in state plane coordinates) using Corpscon batch convert, then import the points (after conversion to state plane) into my CAD program, which obviously has "unlimited" drawing capabities.
RE: GPS software
I use ESRI ArcMap, which I think is far beyond the capabilities you need, though you can likely buy an older license of ArcView 3.x on ebay for cheap. You would also need the Spatial Analyst extension for it. Find as package. This has some of the best point to contour to TIN surface capabilities I have seen.
Chris Erichsen
GeoIntel GIS
WWW.GEOINTEL.COM
RE: GPS software
Thank you for leading me to Terrain Navigator Pro, I purchased a personal copy for myself for trial reasons. So far it is doing everything I need it to do.
I looked at ESRI ArcMap and that is much more powerful than I need it to be.
Thank you all for your help.
RE: GPS software
Yeah I use terrain navigator quite a bit for preliminary work...if you did in fact get the pro version, you also have a 1-year access to aerial photos that can be downloaded and saved with georeference files as well.
