Forming - Joggle Tonnage Calculation
Does anyone have an calculation to estimate the tonnage required to form a joggle or offset bend in sheet metal? Most texts will give an estimate between 3 - 6x the tonnage for air bending?
RE: Forming - Joggle Tonnage Calculation
A good starting point is
Length of form (mm) X Material thickness (mm) X tensile strength (kg/mm2) X .4
This will give you an answer in kg.
If you start introducing any coining the value will soon shoot up.
Dear Sirs,
I have one question. I am looking for producer of Hot Joggling machine. Please have you this information. Thank you very much for reply. Best Regards Libor PĂ­rko
