Assembly Working Planes
When working with an assembly, any assembly, I often constrain parts by working planes & axis--which are made in the assembly file.
I always turn them off once I'm done using them, and make sure all working planes & axis are turned off before I save and close the assembly.
However, every time I reopen the assembly to edit it or place it as a subassembly into another assembly project, ALL THE WORKING PLANES & AXIS USED ARE TURNED BACK ON.
Is there a way to fix this, so that I don't have to spend 15 minutes going thru the browser selecting & turning them all off?
RE: Assembly Working Planes
CTRL+/ = Origin Axis visibility
CTRL+. = Origin Point visibility
ALT+] = User Work Plane visibility
ALT+/ = User Work Axis visibility
ALT+. = User Work Point visibility
David
Does that mean there is no way to keep work planes turned off, so that they don't always show up when opening an assembly?
Mike
90% of a project takes 90% of the time...the last 10% of a project takes the other 90% of the time!
That is exactly what I said just I listed the hotkeys rather than the menu selections.
David
