Natural Convection Heat Sink Analytical Model
I need to learn how to create an analytical model of plate fin natural convection heat sinks to estimate the thermal resistance from component to air.
I have had no luck searching for papers, texts or online guides. I have found several online calculators but I would like to create my own analytical model.
If anyone knows of papers, texts or online guides that may help then I would be grateful for the information.
Thanks.
RE: Natural Convection Heat Sink Analytical Model
This sort of model is pretty much in every heat transfer text.
TTFN
Tobalcane
"If you avoid failure, you also avoid success."
IRstuff and bplwithu - I went through several heat transfer texts a while ago and don't remember seeing details about multi-finned heat sinks. I know there are models of natural convection over single vertical plates (as expected) but I am looking for something that brings together all the aspects of a multi-finned heat sink, including air flow effects.
Twoballcane - I need to analytically model the resistance from the back of the heat sink itself to the air.
Transient1 - I will take a look through the journals.
However, I think that you'll find that a purely analytical model is unachievable; there's a reason people created numerical analysis and FEA.
TTFN
Thanks IRStuff, however I believe that it is definitely possible to create an analytical model that gives a fair estimation of the result. I have seen several calculators that use analytical models and have seen a method with critical equations missing. I am using computational numerical analysis however an analytical model will provide results a lot faster.
http://www.r-theta.com/rtools_front.html
the textbook Heat and Mass Transfer, Yunus Cengel, Section 9-4 .... deals with exactly this topic, equations and an example.
the textbook Fundamentals of Heat and Mass Transfer, Incroprera and Dewitt, Section 9.7.1 .... equations and examples.
regards,
magicme
there's no place like gnome.
