Curved Concrete beam tendencies
Gentlemen, I am working on a round building with a circular perimeter beam (68' building diameter). I am concerned that if I specify curved reinforcing bars that the steel will want to "straighten out" under gravity loads.
I have modeled the structure in STAAD using two (2) differing layouts.
In the first layout, I use straight beams from column to columns and apply my edge loads to the beam with an appropriate eccentricity to generate the equivalent torsion. In most, but not all cases, the actual construction can use straight reinforcement with the additional concrete needed for the radial shape being scabbed onto the straight beam.
In the second model, I still use straight beams, but have multiple segments between columns to more closely match the radius of the structure. I consider this to be a model for curved longitudinal reinforcement.
Both models appear to give close and reasonable results, but I wanted to ask if anyone has any information or suggestions that would apply.
Thanks.
Thanks.
RE: Curved Concrete beam tendencies
