2 equal sized motors on 1 VFD
Is it possible or will one motor feedback onto the other and cause problems??
2 equal sized motors on 1 VFD2 equal sized motors on 1 VFD(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: 2 equal sized motors on 1 VFD
Keith Cress
just remember to size the VFD hp x 1.33 (total hp of all motors) or you will undersize the vfd.
Other advice is to size the drive(VFD) on the current rating of each motor x 1.1 to provide a safety margin for overloads.
I know this sounds obvious, but you'd be surprised how many people don't think this through...
I've got to ask, why a safey factor for multiple motors?
Keith Cress
Keith Cress
I guess fans that are the same do not need this multiplier.
Another comment as controlsdude surmised is that centrifugal fans and pumps are variable torque loads where conveyors, positive displacement blowers and pumps, etc. are constant torque loads which will make a difference in loading at less than nominal speeds.
Good way of killing drives unless they are specifically designed for this. I know some are supposedly able to withstand opening of an output contactor or load-break switch but not all drives will put up with this. Of course shutting down the drive for a few seconds would work too, and on a fin-fan cooler this would probably have little consequence.
I believe you would get an overvoltage fault on the drive if you switched one of the disconnects off. You should as a general pratice to have an aux contact on the disconnect that pulls the enable on the vfd to prevent this type of situation either through the plc or hardwired.
I had a job where their was a backup motor and used contactors to swapped between motors with a keyswitch. Their was some interlocking between the disconnect aux and the contactors, and the enable on drive to prevent opening the output between the motor and vfd.
If your going lock out one, then you need a written procedure posted at vfd that you need to shut both off before switching over to just one.
But here's the upshot: when you have multiple motors running downstream of a VFD and one trips off line, the dv/dt issues with regards to damaging the output transistors are somewhat mitigated by the fact that there is still an inductive load running in parallel, absorbing a lot of the voltage spike issues created by the contacts opening. I have used Motor Starter protectors (IEC manual motor starters) as downstream protective devices for years, never had a problem. They take care of the individual OL protection as well as the short circuit protection, provide the means of disconnect that LionelHutz mentioned, and open all three phases, which prevent single phasing one of the motors.
By the way, to LionelHutz's defense (not that he needs it), I don't believe he meant using the downstream disconnect to open one motor circuit while running. His comment came after ScottyUK's concern about running one fan after the other had failed. So if one motor fails, a lockable disconnect allows the user to RESTART the remaining fan while the failed one is being serviced.
another point to ponder.
You mention that the VFD is going on a ship.
VFD's on ships will generally require some sort of certification from Lloyds Register or ABS otherwise the ship owner might get a little upset you putting it on there. They generally have to be carefully selected with regards leakage current and control isolation. Make sure any sort of RFI filter is disconnected or specially designed for ship applicatiuons otherwise the leakage current will be a problem.
The same entities require individual motor overload protection (they don't all agree on the settings, but ABS is 100-125% FLA), but you can have the OL relay isolate the drive input.
