Revolve Cut A Surface
I am looking for a way to revolve cut a surface in one step? I currently create a second surface using the revolve feature, and then use trim, and then delete the trimming surface. Isn't there a simpler method?
RE: Revolve Cut A Surface
CJ Goodrich
Product Design Engineer
Leatherman Tool Group
Portland, Oregon
You can't cut a surface, you can only cut with a surface. Surfaces must be trimmed, not cut with other surfaces.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
