Strain Rate Effect
Strain Rate Effect
Please explain the strain rate effect on steel and why strength increases. Also, how much does the strength increase? And finally, what other materials experience an increase in strength due to strain rate?
RE: Strain Rate Effect
Save water Drink Beer
Perhaps this will give you a beetter insight into strain hardening mechanisms and their effect on properties of steel.
Sorry for my previous curt reply.
You may be surprised at the number of students who post their homework here at Eng-Tips. Thanks for further clarifying your request. There is a ton of good information freely available on the web on this subject. Try the following:
http:/
http:/
http
http://w
With regards to strain rate sensitivity, the following articles discuss a few of the common structural metals:
http://ar
http://ar
There is plenty of information to review on this subject by simply using Google
http://ww
In some materials like high strength stainlesses you can get different results in a tensile test just by changing the strain rate.
Still trying to help you stop corrosion.
formerly Trent Tube, now Plymouth Tube
eblessman@plymouth.com
or edstainless@earthlink.net
