Converting strange video composite signal
we want to record a video signal from a video output of an elder HP-70206A spectrum analyzer. Its horizontal is 24kHz, its vertical frequency is 60Hz, with 1Vpp.
Now we look for a scan converter which scans and converts this signal to a video signal compatible with a PAL standard composite video signal which we can record with a common DVD-recorder or with a video grabber card on a PC.
Do you have any suggestion which company sells such a scan-converter or manybe a flexible video frame grabber card capable to help us.
Andy
Andy
RE: Converting strange video composite signal
If you get black bars, then select the 'slow shutter' function.
In any case, most higher-end frame grabbers have fully programmable timing, something like:
http://w
but, if you look around, there's bound to be something less expensive.
TTFN
