Basic Node Modeling Question
I have a site that has a topographical high point in the center which drains into two separate drainage areas (wetland drainage ditches/swales).  The drainage areas are paralel to each other and run straight through the site.
My question is, how detailed does the routing diagram need to be?  I delineated the drainage area in a great amount of detail on the topo map, however, I would end up with close to 40 nodes to define each drainage pattern.  Do I need a node for every change in slope?  Part of my problem is that the drainage area (or valley) receives drainage along the entire length of the site - do I need to stress about the channel length when the channel is receiving runoff along the entire length?
Any information or advice is greatly appreciated.  I am not a civil engineer and have little experience with this level of detail with the modeling and just want to get a reality check.
I have gone through the tutorial and manual and can not find any clear guidance on this topic.
Thank you in advance.
RE: Basic Node Modeling Question
Your question really pertains to the use of the basic SCS/NRCS methodology, rather than HydroCAD itself.  You may want to review some of the general background material in the HydroCAD Owner's Manual and Training Manual, as well as the TR-55 manual, which has several examples concerning subcatchment delineation and Tc calculations.
As a general guideline, use the simplest model that will meet your design and modeling objectives.  It's possible that your site may have just two subcatchments, with each swale represented as a flow segment (channel flow) within the Tc calculation.
For a discussion of channel modeling options please see www.hydrocad.net/reach.htm
For general Tc issues see www.hydrocad.net/tc.htm
Also please see the general how-to at www.hydrocad.net/howto.htm
Peter Smart
HydroCAD Software
www.hydrocad.net
cf,
How big is the site?
You say you have little experience with this level of detail. I am not trying to be judgemental, but it concerns me that you have 40 nodes for 2 drainage areas.  I would typically expect 2 nodes for 2 drainage areas.  As Mr. Smart suggested, this sounds like a matter of becoming educated in SCS hydrology.
