K Value for Wafer Check Valve?
I am doing some hydraulics and I can't seem to find the k value for a wafer style check valve anywhere. Anyone know where to find it or have an approximation that they use? I also need the k value for a duck billed check but I am not sure that there is a k value out there.
Thanks in advance,
Nathan
Thanks in advance,
Nathan
RE: K Value for Wafer Check Valve?
Will vary according to construction and exact size and dimensions. Find a decent supplier, they will publish on homepage or tell you direct.
If your waterhammer analysis determines that you dont need this sophistication then try the Tyco Water website.
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
www.waterhammer.bigblog.com.au
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
Steve Wagner
