Appendix 13 - other code for circular section with central dividing pl
Does anyone know of other code or method to assess the stresses in vessels of circular cross section with central dividing plate [with differential pressure]:
References useful for this, as I know, are:
* ASME VIII division 1, appendix 13;
* TEMA code (RCB-9-13);
* Roark & Young, chapter 10.10, tables 26 8a et 26 9 Bending of uniform-thickness plates with straight boundaries
Any other clues?
Yours truly,
tigny
Any other clues?
Yours truly,
tigny
RE: Appendix 13 - other code for circular section with central dividing pl
I'm still working this subject, and request some help.
- In chapter 13-4 of Appendix 13 (ASME VIII section 1), it is stated that ...The joint efficiency factor E shall also be
- An other question on the same subject,
Yours,applied to the allowable design stress for evaluation of the
calculated bending stress Sb at the location of the joint
only. See 13-l(d), 13-5 footnote 1, and 13-8(b).
Does this mean that bending stress shall be compared to allowable SE?
So far I thought only membrane + bending should be compared to the allowable, in general 1.5SE
Please find a link to my file.
what category would you apply to the welds of central dividing plate?
Category C: any welded joint connecting one side
plate3 to another side plate of a flat-sided vessel. (typography is not clear in the code; does it lack some comas?)
Category D: Category D. Welded joints connecting communicating chambers [...] to flat sided vessels
tigny
