Pretension needed to prevent separation
Could anyone recommend a reliable resource/text book/software package that would allow me to analyze a bolted joint to determine the amount of pretension required to prevent separation for a given load?
RE: Pretension needed to prevent separation
http://
http://www.hexagon.de/sr1_e.htm
I use most of the times:FED-STD-H28/2B (1994)
"Federal Standard
Screw-thread standards for Federal Services
Section 2"
Appendix B is a Design method of Unified Screw Threads.
This public document can be dowloaded from:
http://assist.daps.dla.mil/quicksearch/
You could also try Mike Niu's Airframe Stress Analysis and Sizing
Or the Fokker Stress Handbook TH3.561 might be used (proprietary document).
See also the thread:
http://www
Stressing to the maxx.....
MDESIGN bolt by Tedata
http://www.tedata.com/index.php?id=54&L=2
MITCalc
http://www.mitcalc.com/en/pr_boltcon.htm
As far as books go, here are the best ones:
Handbook of Bolts and Bolted Joints edited by Bickford and Nassar
An Introduction to the Design and Behavior of Bolted Joints by Bickford
Both books are published by Dekker/Taylor and Francis:
http://www.taylorandfrancis.com
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Hi Yeoman
Have a look at these sites they may help:-
h
http://www.co-design.co.uk/dpg/bol/bol3.html
http://
http://ww
regards
desertfox
