winding configuration of generator step-up transformer
what winding configuration of generator step-up transformer is most used in North America when generator is connected to LDC feeder?
delta on HV side or delta on LV side?
RE: winding configuration of generator step-up transformer
example is Feb 2006 thread named:" Advantages and Disadvantages of Delta-Wye and Wye Delta ... )
What do you mean primary and secondary in step up trnsformer?
Ppay, I agree with David.
Regards.
Slava
Primary is always defined as the one that receives the supply. In this case, it is the generator side.
Thnaks , we talk about same.
I ask only for to be sure, not for check you
Regards.
Slava
Always pleased to oblige.
to be solid grounded.
