3D XML
3D XML
I have Dassault System 3D XML Player.
It works with its example file but it doesn't work
my 3DXML file which is produced by Save As in CATIA.
RE: 3D XML
What error does it say ?
If you upgraded Catia lately, you also have to upgrade the 3dxml viewer.
You can also try to have a look "inside" the 3dxml file by renaming it with a ".zip" extension at the end of the file, so it will open with winzip.
Me, I had (or still have, I have to check every new file I create) a problem because there was a file with a "path" inside the 3dxml. Just removing it from the .zip file fixed it (thanks to this forum).
RE: 3D XML
Hi prolynx,
I have tried what you said.
I saw that file then I removed.
But I could not run it again.
Do you have any idea?
Regards.
RE: 3D XML
What is the error message ?
Rarely it helps, but it's good to know...
RE: 3D XML
The error message is "Loading failure error"
RE: 3D XML
unzip it and have a look if it contains dodgy filenames
