Nested Configurations and the API
I am trying to use a design table to build nested configurations. This seems to be impossible. As a second option, is there a way that I can programatically move a configuration in the configuration tree?
Any help would be appreciated.
RE: Nested Configurations and the API
Unfortunately you can´t add nested (derived) configuration using Design Tables or API.
The only choice you have is add manualy a derived configuration through the configuration manager.
Hope that helps.
