Excel for wet-well and pump sizing
I compiled this Excel program as to help me in the design of wet-well and pumps. Can someone check if there is something that I missed out and also tell me how to animate the program so that when less than the number of the pumps shown on the diagram are required(like when 2 pumps are required instead of 4, the redundant 2 pumps on the diagram disappear; both from the diagram and in the calculation, leaving behind only the number(s) of pumps that are specified for, both in the diagram and the calculation)
Link to the file is: http://files.engineering.com/getfile.aspx?folder=3bd45546-3646-4298-be52-e10ba4e50763&file=EXCEL_for_Pump_Design.xls
Note: I do not know anything about animation.
Teddy
RE: Excel for wet-well and pump sizing
You might check out
Lift station design
thread770-160272: Lift station design
http://www.eng-tips.com/viewthread.cfm?qid=160272
and
Distance from inlet to suction -wet well
thread164-153148: Distance from inlet to suction -wet well
http://www.eng-tips.com/viewthread.cfm?qid=153148&page=5
stanier wrote: "ITT Flygt have some great publications on the design of wet wells. In addition their Secad software allows the design of wet wells and covers all you need. In addition ABS pumps have their PSD software that aids the design of wet wells. If you were in Sydney I could help further with resources."
Here's some links for you that might be helpful in comparing your spreadsheet results to other analysis packages...
ITT Flygt Engineering software
http://int.flygt.com/142575.asp
http://www.flygtus.com/118460.asp
ABS Pump Selection & Planning Software
http://impeller.net/magazine/news_en/doc2385x.asp
http://impeller.net/magazine/news_en/dx826z.asp
http://www.abspumps.com
Pump Ed 101 (Understanding Pumps, Motors, and Their Controls)
http://www.pumped101.com
Flowserve Corporation Software
http://www.flowserve.com/eim/CustomerSupport/SoftwareDownloads
Vertiflow Pump Selection Software
http://www.vertiflopump.com/bob.htm
Myers Pump Software
http://www.femyers.com/software/Myers%20Software.html
Tuthill Pump Group Software
http://pump.tuthill.com/Support/PX/index.cfm
tsgrue: site engineering, stormwater
management, landscape design, ecosystem
rehabilitation, mathematical simulation
http://hhwq.blogspot.com
