Excavaror mounted hydraulic hammer gat material?
I am looking for information on the grade of steel of the Hydraulic hammer "gat" or "bit" that is used to chrush rocks or break up concrete slabs. I am trying to turn a custom adaptor to weld to the end of the bit to hammer plate piles into medium hard sand stone.
Any information on the material, gtaw electrodes, welding procedure, pwht, etc, are used for a high impact bit such as this would help point me in the right direction on this project.
RE: Excavaror mounted hydraulic hammer gat material?
C-0.25-0.3%, Mn-1.2-1.3%, Si-0.5-0.6%, Cr-1.2-1.5%, Mo-0.3%.
These are then oil quenched and tempered to 38-40RC hardness.
A cheaper alternate material is high manganese hadfield steel.
" All that is necessary for triumph of evil is that good men do nothing".
Edmund Burke
Edmund Burke
Still trying to help you stop corrosion.
formerly Trent Tube, now Plymouth Tube
eblessman@plymouth.com
or edstainless@earthlink.net
Ed Danzer
www.danzcoinc.com
www.dehyds.com
