P&ID symbol for a Fire Safety Valve at bulk store tanks
I was hoping someone could point me to the correct P&ID symbol/symbols to be able to show what we refer to as a "Fire Safety Valve" which is an isolating valve with a fusible link.
The valves are to be mounted at the bottom nozzles in the feed and discharge of various 10,000 BBL storage tanks located within an existing storage terminal tank farm.
The Fire Safety Valves shown on the existing P&IDs are just shown as normal valves without any form of actuation or fusible links and these will be updated with the correct symbol once I confirm what it is.
Thanks in advance.
Thanks in advance.
RE: P&ID symbol for a Fire Safety Valve at bulk store tanks
As you can see this particular forum doesn't get a lot of traffic, but best of luck.
Flash
Me wrong? I'm just fine-tuning my sarcasm!
