Interior CMU partition foundation
We typically specify thickened slab and dowelled rabar for interior CMU partition walls. We don't use a lot of CMU so it was never a big deal. Now we have an elementary school that is chock full of them. Has anyone ever used some type of post-installed shear connector that can be easily fastened (screwed) to our 5" slab?
Seems like this would be tons easier on everybody.
tw
tw
RE: Interior CMU partition foundation
It would be cheaper and quicker to epoxy the dowels 4" into the slab.
Mike McCann
McCann Engineering
I would agree with Mike though that epoxy anchoring the dowels would be better and easier for the contractor if you didn't want to use embedded dowels. I could see it being a nightmare trying to accurately locate and hold in place mechanical anchors in the slab during concrete placement.
DaveAtkins
I do not believe tw was referring to wet setting the anchor.
The anchor I was referring to still has to have a pre-drilled hole, and was made by "Red Head". It is termed a "non-Drill Anchor" and is covered in an ICBO report #1372 dated Feb, 1975. You can probably get the current, updated report online if they still make them.
Mike McCann
McCann Engineering
I would still put minimum reinforcing in the partition wall and tie it to the slab, but I am in a high seismic area too.
Mike McCann
McCann Engineering
I've never done it this way & that is really my question: Has anyone done it that way?
tw
Mike McCann
McCann Engineering
Option I will likely use is to use some type of non-drill anchorage that will provide the connection & work with just the 5" slab.
thanks for the input
tw
Dur-O-Wal makes an interesting anchor, Dur-O-Wal DA8800 OCM Anchor. I've never specified it myself but it may be OK for interior walls. I would definitely use some sort of dowel instead of leaving them out. I would also provide a footing, even if only 8x16.
Mike McCann
McCann Engineering
You're right - a mechanical anchor could be set in drilled holes. For me though, if they're already drilling the hole why not just put the epoxy in there.
Mike McCann
McCann Engineering
