CATIA Drawings
CATIA Drawings
CATIA Drawings
Quick question.
When a user creates a new sheet on a CATIA Drawing, if there a way to reorder the tabs automaticaly?
Thanks.
RE: CATIA Drawings
macmmc,
no nothing automatic,but you can select sheets in order you want then cut and past.
Eric N.
RE: CATIA Drawings
Cut and paste doesn't work really work for me. Can you discribe the process in more detail.
Thanks!
RE: CATIA Drawings
I got it figure out. Guess I should read better.
Select sheets in order. Then paste. Then delete old ones.
RE: CATIA Drawings
mmmmm I just right click on the sheet in the specification tree and chose reorder and then indicate after which sheet you want to place it. I'm on R18SP3, don't know if that is a recent feature.
RE: CATIA Drawings
it is new in R18...
Eric N.
